Bob's RV-8 Build Site
Date:  9-2-2023
Number of Hours:  5.80
Brief Description:  Sand Fiberglass Parts Part #1
So I worked all day on sanding the cowls and some other fiberglass parts. I began with the bottom cowl. I had already did a test area where I wanted to see how the Super Fil would work to get the divots in the center of the honeycomb filled. This took a lot of work with the Smooth Prime for the top cowl and I didn't want to do that again.
I sanded the test patch off until the superfil got thin enough to see the honeycomb. It seemed to fill in the divots excellently! I plan on doing the whole area where the honeycomp matte is placed.
I then used sandpaper to take off the shiney glaze off the wheel fairings....I use 150 grit which does a good job.
The temperature has risen again but it was bearable doing the work in the shade.
Cowl being sanded with Superfil
SuperFil Sanded
SuperFil Sanded
Wheel pants sanded
Wheel pants sanded
