Worked on the baffles and the snorkel. I had to modify the inboard bracket on the left front inlet baffle as it was interferring a little bit on the engine crankcase. I was able to use the dremmel and remove a little bit of material in order to give some clearance. After doing that the baffle fit into place and everything aligned.much better.
I moved on to the snorkel. I have to attach the brackets and I fiddled with the brackets and worked to get things in place and aligned. I opened up the holes in the attachment flange for the servo as they had absolutely no clearance between the screws and the holes. I then worked for a little on getting the brackets all set up to get riveted to the snorkel.
