Bob's RV-8 Build Site
Date:  8-27-2023
Number of Hours:  2.20
Brief Description:  Left Front Baffle and Alt Air Bracket
Got a little shop time in after a week long work trip.
I made a bracket that Ralph gave me a pattern for that fits over two bolts on the forward valve cover that holds the Alternate Air cable. I fashioned the bracket and drilled it for the locations on the two screws for the valve bracket. I set the bracket on the cover along with two washers in back to fill in the gap on the valve cover due to the lip on the cover.
I then drilled the final hole in the bracket for the -4 Adel clamp that would hold the cable. I put the secondary rear clamp on the rear cylinder oil drain line per Vans instructions.
I decided to temporarily install the left front baffle to make sure nothing interferred with the clamp and the cable. The baffle took a little bit of fiddling with but looks like all is good. I will need to remove it in order to finish off some snorkel work....but at least all is looking good so far.
Bracket on valve cover
Adel clamps added
Adel clamps added
Front baffle temp install
