I had to put some of the left console skeleton together to hold the left console panel while determining the attachment of the adel clamp location and cable length for the lever. While setting angle for the skeleton in place I found some interference with the CB panel since I haven't had the piece on since doing the electrical. So I proceeded to modify the part to fit the area.....most of the area where the problem was allowed me to remove the material I needed.
After getting the modification done, I set the panel in place and got the cable positioned to mark where the adel needed to go. I drilled the hole for the adel and using the location marked where I am going to have to cut the Boden cable sheathing for the cable length. To be continued next time......
