I had a little time before quitting for the day so I decided to pull out the seat and misc other panels to get the aileron trim installed at least to the point of the lever on the side.
I elected to go with manual aileron trim so I have a cable to install along with the rod and the bias spring setup. Given the choice I will always take manual trim...unless there is an autopilot that can use the electric trim while I am using it as is the case with the pitch trim servo.
There was a lot of fiberglass cleanup so that was a lot of the session and then I was able to get a little actual work done.
