Bob's RV-8 Build Site
Date:  6-13-2023
Number of Hours:  1.90
Brief Description:  Sand Cowl & Rear Throttle
Mostly spent time sanding the upper cowl of the Smooth Prime.....just lots of sanding...
I then just did a little adjustment of the bulkhead hole for the rear throttle rod so that the rod end bearing would fit through for ease of install and removal. I also took a little off the rear end of the rod for increasing the adjustment parameter.
More Sanding
More Sanding
Rear Throttle End
Rear Throttle End
