Bob's RV-8 Build Site
Date:  5-27-2023
Number of Hours:  1.30
Brief Description:  Throttle Quadrant
I worked on gathering the quadrant and parts to get it installed in the cockpit. Inbetween priming and cleaning out the pan, brush, and roller I worked on the quadrant in order to prepare to get the engine cables hooked up
I put the parts to install the quadrant to the spar cover that I had made so many ions ago. I then took the quadrant along with the hardware to get it installed in place.
I have to get the rear quadrant completed as well as the cables so I wanted to work that inbetween the priming.....
Quadrant installed in place
