I worked on the cable rod end attachments for the mixture and throttle cables. I bought longer bolts in order to get the cable ends higher in order to lessen the angle of the cable rod.
I put the required washers on the bolt and then measured the distance and made spacers to slide in between the rod end and arms of each attachment and made the spacers on my lathe.
There are a lot of adjustments on the rod end, the cables a multiple places on the fuel servo so there will be more fiddling as I get the throttle quadrant installed.
For now I only have a little more work on the rod ends connecting the throttle body.
