I sanded the glaze of from the last session. I used a more focused approach to remove the glazed areas. I used my small needle file set to knock down the areas and leaving only a little to remove with sandpaper. Then I went to 320 grit sandpaper and used a popsicle stick to focus the sanding to only the glazed area.
After finishing sanding the areas I applied another coat of primer. There were some more pinholes but no more larger cavities to fill. So later I filled the pinholes and will wait for the glaze to cure.
