Bob's RV-8 Build Site
Date:  5-9-2023
Number of Hours:  1.30
Brief Description:  Connect Oil Lines
Leaving the glaze to cure I decided to attach the rest of the oil lines I received from TS Flightlines.
I installed the new hoses to the oil cooler. The fit was a lot better and I was able to put loops in each to allow the hoses to flex when the engine twists in the mounts to alleviate putting strain on the hoses that attach to the oil cooler. I removed the inboard bolt on the oil cooler in order to put an adel clamp on the outboard hose to keep it from chafing on the oil cooler.
Next I routed the oil line for the prop governor that has been modified......now it routes and fits great with slack for snaking it through from front to back. I still need to put some support clamps on the hose but I am pleased with how it all fits.
Oil Cooler Hoses
Oil Cooler Hoses
Prop Governor Hose (see arrows)
