Since we had three of us working here today we pulled one wing out of the cradle and set it on the table in order to get the fuel cap inserts installed. Rick and I prepped the fuel filler areas and mixed a batch of pro-seal.
After sanding the insert with 80 grit sandpaper we marked the insert position, then we gooped it up and set it in the filler neck, wiped off the excess pro-seal and allowed it to cure.
