Bob's RV-8 Build Site
Date:  3-10-2023
Brief Description:  Snorkle & Windscreen
Got some shop time in today. I started by mixing some micro epoxy and laying some on the final area of the snorkle that needed it then set it aside to cure.
I went back to the windscreen. I ended up sanding more of the winscreen off at the very front of the windscreen trying to get it to fit as it needs to. After I was pretty happy with how it laid on the airplane I marked a bunch of lines on the windscreen and then made matching arrows on the top of the aluminum skin to act as reference marks to line up the windscreen the same place and way every time I made an adjustment. After playing arond with that for a while I felt I was finally getting closer to having the fit correct.
I then went back to the snorkle and began sanding the micro down....just a long tedious task to finish off the session.
Laid more micro in the morning
Worked on positioning windscreen for a bit
Sanded snorkle for a while....
