Brief Description: Oil Cooler Install and Snorkle Micro
Worked a bit today on keeping the micro going on the snorkle. I set up so I could lay micro on the underside. The key is getting it as level as possible in order to keep the micro from oozing down and making "glob waves".
While micro was curing I went back into getting the oil cooler re-install completed and ops checked.
Before ending the session I applied micro to the side of the snorkle.
In between I had a great conversation with Rick about attacking the canopy and windscreen fiberglass work for close to an hour......didn't record that in the log time but it was a great strategy session.
