Worked the flanges for the rear baffles. Started by deburring all the cutouts I made in the last work session.
Some of the flanges needed holes drilled in them for riveting the flanges to the baffles so I figured out the drill pattern and got the holed drilled and deburred.
I aligned the holes of the flanges in location and lined them up exactly centered on the hole cutouts on the baffles and match drilled the flanges in place.
Just have to complete the ignition wire pass-thru's now.
