Finalized the major holes for ducting and pass thru's for ignition wires. I measured and formulated what I had to have for clearance on the ignition wire pass thru and then went to cutting the necessary holes on the right rear baffle and then the left rear baffle.
I will probably attach the pass thru's using nutplates and will drill and countersink for them but will wait until after coating to install them.
