Brief Description: Work Left Ramp and Filter Brackets
I began the session by match drilling the holes for the outboard filter bracket which required once again removing the bottom cowl.
After drilling the outboard bracket I began to mark it for cutting it to conform to hold down the filter as per the plans. I then got the inboard bracket and marked it prior to ending the session.
