I started by getting the clamp I made for the starter wire installed and the cable routed and clamped.
I was working on the Pmag ignition switches as Ralph and I had cut the looped bundle that we pulled through for both left and right ignitions. Ralph identified the wires for the left and right side then I climbed into the cockpit to hook up the ignition switches. A bit tedious but by the end of the session the right console was pretty much finished. All the wires are attached but the wires need to be tidied up a bit and bundled and laced in a few places.
