On tonights short session I was figuring out the grounds for the three warning lights that I have on the right console. I have the starter engaged light, and the main & standby alrernator fail lights.
I want to be able to remove the panel and the lights without cutting wires. So I finally decided to use knife splices and put the three grounds on one fast-on tab to the grounding block. The lights draw so little power it is the most optimizing way to do it.
So I made up the triple wire bundle and placed it on the forest of tabs in the avionics area.
