Brief Description: Right Console Switching Panel #3
Spent more time on the right console panel. I decided that I could use a single ground for the three lights in the right console panel. So I used the main ground wire which was a 22 AWG to pull through a 20 AWG. It was probably absolutely unnecessary but it was easy to do at this point so I figured why not.
After pulling the new ground and making a new label that it woud be for the three lights, I removed the TCW Backup battery mini locking toggle switch and brought it over to the airplane in order to get the harness wires soldered on to the switch. I had to set up a board across the cockpit in order to set my little holder and be able to have the wires reach while soldering. All worked well and I made more nice solder joints.
I next took the right console panel to the airplane and started sorting through the wires for getting them connected to the panel. these will use screws but routing the wires and getting them where they need to be will take some time........
