Brief Description: Wire GT-50 and Boost Pump Switch
I worked on the left side of the panel to work some wiring. I installed a cable standoff on the avionics rack support to hold the wires going to the GT-50 Chrono/G-meter and the Boost Pump wires. Got those two items wires routed and mostly wired......I still have to wire the boost pump incicator ligtht wire with the switch wire.
I was checking the continuity on the GT-50 and discovered a short at the connector. I began to trace it and determined there is something shorting out my Buss A on the fuse block. I will check what is going on next session and remedy that problem.
