Got a little work done tonight.....mostly administrative. I made up the finalized matrix for the Fuse Block. I was thinking of getting a rub on label for attaching it to the panel next to the fuse block but I decided against the idea because there may be changes in the future to fuse block and wiring and that would make the matrix obsolete. Instead I will put a page in the aircraft checklist for referencing as well as any other notes concerning the fuse block. I did make up a label to put on the fuse-relay panel saying to reference the checklist for fuse information.
I then decided to run the last two wires for the "Starter Engaged" light that I have on my right console panel. I will be using an inline fuse for protecting the wire since it comes directly off the big lug or the "I" post of the starter solinoid.
