I continued working the fuse block. Getting the terminals crimped on correctly is what takes the most time in the process. The pins and the molex crimper work fine but it just takes a little bit of time to get it right and do a good job.
I also ran more wires for the PIC USB that is just a short run for the power but I decided to run the ground to the firewall ground block as it was the best way to route that wire. Progress on the fuse block continues to be made......
On a side note my upgrade for the Milling Machine was installed today. I only had the dials to use for a couple simple projects....what a difference having the digital readouts and functionality of the CNC to assist in doing things. The mill has been down since the first week of January.....guess it spoils you a bit.....
