Lots going on last night so it was a shorter session in the shop. I received my order of Dsub male and female pins so I could get the other half of the Dsub grounding connector made. I had a little scrap I could use but then had to cut lengths of wire for the remaining lights.
After cutting the wires I pinned them with the Dsub pins. I routed the wires to the empty indicator light holes. Next will be routing the wires and soldering the connections for the wires and placing labels on the wires.
