Brief Description: IGN Buss and Right Console Panel
I worked on making and routing the Ignition Buss wire up to the circuit breakers to get them the power needed as I spoke about in the last session. I am running the wire such as the Fuse Block will be able to be pulled out of the panel if needed with enough slack on the buss wire to allow it to do so.
I used some very small spiral wrap on the 14 AWG wire to additionally protect the wire from fraying and being shorted in the process. There is really no areas of concern for the wire to rub on but I am taking extra measures to assure protection. I am even pondering running a second wire off the fuse block C Buss lug to have redundancy.....we will seel The breakers will be able to crossfeed to each other through a connecting wire or buss bar.
