Brief Description: Ground Wire Terminals for Panel Ground Block
Changed the adel clamp to the next size smaller because the bundle of grounds were too loose in the clamp.
Then I started to layout the ground wires in a semi logical way that would group them together in a very general way. I made up a chart on a pad of paper that would list which ground was on which tab on the bus bar. I worked my way from left to right across the forest of tabs.
As I attached the wires I marked their location of which ground tab they were located. Fortunately the wire marking sleeves were able to be moved in order to position them on the wire after getting the terminal attached.
