Brief Description: Install Front seat floor - Flap actuator nutplates
Started with looking into the Pmag installation manual. A question came up about timing and I wanted to see the limitations of the variable timing on them and had a conversation with my friend Jim about several aspects.
I continued working on installing the forward floors and the PIC seat and then got the ramp parts installed. I am mainly doing so to get the seat height determined for my cores that I will be getting from Oregon Aero and want to give them a height of the cushion. But it is also a test fit on the panels and seats to make sure all is as it should be. In my last log I mentioned some things that needed to be addressed that were overlooked or missed.
I decided to install nutplates for the attachment of the flap actuator to the airframe on the bulkhead where the top end of the actuator arm attaches.
Finally I worked on the baggage area flooring that needed some holes match drilled.
