So today was a lot of miscellaneous activities. After starting with a discussion for a bit with Ralph who has been keeping me straight on all things "electron" related, we determined that some things needed to be altered in the system. The GTN 650 is using TCW pass through power to supply current to the box....so that basically means I don't need two circuit breakers on the CB panel. In light of that I decided to split off the pitch and roll servos to isolate them in the event of failure that I could still use one axis or the other.
So that means modifying the CB panel which will need new labels. In the process I was just going to remove the necessary labels....but in the end I decided to remove ALL the labels and sand and repaint the panel. The CB lockwashers deformed the paint when tightening the CB's so I figured what the heck...get it fixed!
I made up new labels and did some work on the fuse block as well.....a real mixture of tasks today.
