I got the mount for the right flap weldment mount that will hold the bracket for the Advanced AOA Micro Switch that tells the flap position (up or down) in order to send the information to the AOA computer.
I finished tweaking the position of the micro switch on the bracket and marked it for the location of the switch position. I then took it to the shop and place the slots into the locations of the bracket mounting bolts for the bracket and the micro switch attaching bolts.
Should be able to install the switch next session to check things out.
