I began to work on a design for the flap position sensor mount that will give the flap position on the PFD. The key is getting the sensor in a location that it will stay within its approximate 1.25 inch travel.
I am planning to hinge the mount to the bulkhead in order to allow the sensor to move with the changing arc of the flap weldment. I made up a hinge out of some -1 hinge stock I have. I installed the adel clamp that is modified with the tab that will connect to the sensor. I drilled and clekoed half of the hinge to the mount.
That's all for the design-as-I-go sensor mount for now.
