I wanted to get all the COAX cables run for the various antennas. I started with the GPS antenna on the turtledeck. I pondered for a bit at running the coax and was checking out the TNC elbow to make sure it would fit. The pass through hole for the elbow was a little small....almost size for size. I took a step drill and opened up to the next size.....now it fits easily.
While figuring coax wiring I noticed the screws that hold down the canopy slide rail....hmmmm...I looked and came up with pros and cons.....and decided it would be the best option for holding and routing the coax. I had bought some longer screws for the rail that I wanted to replace and they would work perfect.....so I started getting adels to insert to route the cable.
