Bob's RV-8 Build Site
Date:  1-17-2020
Number of Hours:  2.70
Brief Description:  Sand and profile fiberglass
It never got over 38 degrees today but it was sunny so I went outside to work on all the rough fiberglass work that has been done over the past few sessions.
I set up and started to cut off fiberglass and then using everything from a belt sander to a sanding block spent the next couple hours or so working on the right skirt. I am planning to get it as close as possible before the skirt is all one piece which will make it a little more difficult to manipulate.
A chilly work session!
Working outside on cool day
Getting closer to getting done
A lot of sanding!
A lot of sanding!
