I removed the rail spacer from the fuse and milled off about 1/8 th inch from the rear end of the spacer because it stuck out slightly beyond the cap.
Next I countersunk all the holes in the spacer and the cap for the rivets. I also placed the canopy slide rail back on the fuse and drilled the most forward hole through the rail cap and rail spacer.
