Tonight was more panel planning—sure hope I’m getting fairly close to some kind of final design, cause I’ve spent a lot of time on it. I laid out locations for the light switches as well as the switches for the master, alternator, avionics master and mags. May try moving the vertical compass to the sub panel and centering the TruTrak Gemini. I am only logging time actually doing something in the shop—have not kept up with the countless hours of research and planning regarding avionics, panel design and proposed wiring. Want to be sure I have a good plan before I start cutting and drilling aluminum.
Latest panel design
The yellow is a TruTrak Gemini; switches on the right
