Supported the fuse on some jack stands and removed the rotisserie. Leveled the fuse—lateral was very close to level, but had to raise the tail some. Marked 3/16" setback line where edge of outboard wearplate will sit. Marked the left skin where the outboard bracket will nest. The Grove brackets are a bit larger than the stock brackets. Trimmed the skin on the left side until I got a good fit. Marked the right skin for trimming—ran out of time tonight.
