Steve & Nancy Riffe
Date:  10-2-2011
Number of Hours:  1.00
Brief Description:  Rudder cable install
Been away for a bit—Nancy and I took a much needed vacation. Good for both of us to leave the aluminum mistress behind and spend some time with each other. Spent some time reviewing where I had left off. Removed the rudder cables I had started stringing last session. Smoothed the edges of the skin where the cables exit the fuse. Dimpled for #8 screw to secure rudder cable with a clamp at the exit near the aft end of the fuse. Added the rudder cable, secured with a clamp, and strung the cable up to the forward spar, adding snap bushings as I went. Cut a small slit in the plastic sheathing and inserted a zip tie to secure the sheathing to the F805E cable support. Repeated this process for the other side.
Dimpling fuse for #8 screw
Plastic sheathing secured with clamp
Zip tie to secure plastic sheathing to cable support
