Brief Description: Installed Elevators, drilled horns, connect contro
Installed the elevators—what fun getting the washers inserted at the center bearing. The bottom of the fuse where the tail wheel mount goes is now full of washers! Clamped elevators in neutral postion, marked and drilled hole in first elevator horn. Clamped an aluminum block between the horns to use as a drill guide to drill the other horn. Installed the F841 control rod. Used a tubing cutter to cut some spacers from aluminum tube to insert between elevator horns and rod end bearing of F841 tube. Unclamped elevators and checked operation. Works smoothly-no binding or slop. Need to check elevator travel and adjust up and down stops.
