Darn hot here—104 degrees makes it a bit uncomfortable in the shop! Tonight I drilled four holes with the angle drill to attach two nutplates which will secure the left mid cabin cover to the longeron. Then used c/s and finally installed some cherry rivets to secure the nutplates. Had to use a single lug nutplate in the aft corner, same as the right side. Screwed the right mid cabin cover down and installed the bulkhead cap with clecoes. Screwed the F865-1 console in place. I plan to fab a cover (just as others have done) to fit between the console, the mid cabin cover and the bulkhead cap for installation of circuit breakers.
Left side-added two nutplates to secure mid cabin cover
Right console-secured mid cabin cover, bulkhead cap, console
