Brief Description: Drilling W-816 tubes to VA-111's
Finished fitting and match drilling the 3 remaining W-816 tubes and the VA-111 pieces. As usual, the next 3 went a lot faster than the one that I did last night. I’m not totally satisfied with the primer inside the tubes. Very hard to tell if everything is really covered or not. I used a rattle can to spray primer in the tube until it was dripping from the other end, but still not certain of the coverage. Before I rivet on the VA-111’s, think I will get a can of primer and pour it in the tubes.
