Sanded out the Super FIl I had previously added. Looks ok in several areas, but some need additional work. I added more Super Fil to transition the aft end into the tail light mounting ring. Another area giving me fits is where the bulge for the tail light meets the glass tape I added to cover the joint. After the Super Fil dried, I gave it another sanding, then shot with sanding primer. Still needs more work.
