Removed the left elevator—darn, found one small pin hole—believe I’ll let the paint shop address that issue—I’ve had all the fun I want with this tip. Moved it back to the upstairs closet where it will again reside for some time. Did a little more work on the left HS tip-then I mixed up some micro. Spread the mixture on the flange area of the tip and clecoed it to the HS. Attached the tip with CS4-4 pop rivets and smoothed out the excess with one on Nancy’s credit cards—hope she doesn’t notice she missing one!
