Brief Description: L. Elevator-Rolling Leading Edge
L. Elevator-Worked the center section a little more. Finally got it to lay flat. Drilled to #30 and deburred. Dipped the rivets in primer and installed them. Then, Nancy helped me roll the last section—much easier to roll these leading edges with four hands! Clecoed the rolled edges together—looks ok, but think I’ll work it a bit more. Should be able to finish the elevator tomorrow.
