Brief Description: L. Elevator-Rolling Leadiing Edge
L. Elevator-Trimmed the elevator just a bit, now the servo turnbuckle has just enough clearance. Removed the trim plate & servo and removed the trim tab. Nancy helped me start the “dreaded” roll of the elevator leading edge. Rolled the first short section, and then the center section. Worked the first section just a bit, then drilled to #30. Dipped the pop rivets in primer and popped them in. First section looks good. Need to work the center section just a bit more, then on to the last (and hardest) section.
