Steve & Nancy Riffe
Date:  8-19-2016
Number of Hours:  1.00
Brief Description:  Cowl work-10, oil door hinge
I sanded the top cowl one more time, then mixed up a batch of resin. I poured a small amount into another cup, then mixed in some flow. I spread this on the back side of the oil door hinge, then clecoed the hinge to the door. I squeezed in 4 rivets and cleaned up the excess flox. I then mixed some micro in with the resin I had poured into a separate cup. I spread this on the left half of the upper cowl. This half still had lots of spots where the grain (actually divets) were still present in the honeycomb.
Hinge riveted to oil door
Left half of upper cowl with more micro
