Steve & Nancy Riffe
Date:  1-3-2017
Number of Hours:  1.00
Brief Description:  Sloshed l. tank, install Andair fuel valve handle
I drained the remaining fuel from the right tank, then poured exactly 1 gallon into the left tank. I sloshed the fuel around same as I did for the right tank. Then, I began draining the fuel from the sump drain thru a coffee filter into a jar. Very interesting—I drained out exactly 1 gallon of fuel. The plane was sitting in a 3 point stance. I probably should raise the tail and level the fuse to see if all the fuel still drains out. Next, I installed the Andair fuel valve handle in preparation of checking fuel lines, pump output etc. I also polished the Grove gear and pulled the wiring for the auto pilot roll servo located in the right wing thru the grommet in the side of the fuse.
Fuel valve handle installed
