Steve & Nancy Riffe
Date:  10-2-2016
Number of Hours:  1.00
Manual Reference:  8-70
Brief Description:  Baggage Door Redux-1
Today began the redux of the forward baggage door. The first one just didn’t fit well enough—hope the 2nd one is better. In looking back at my earlier logs, when I built the first door, the top skin was only clecoed on and I did not have the cowl in place (hadn’t even started on the cowl). Part of getting a good fit is having the top skin and firewall in a stabilized and permanent position—anyway not having done that is what I believe contributed to the poor fit. We shall see. Following the builders manual, I deburred the edges of the forward and aft ribs, the outboard rib, both inner and outer skin and the F-873F-1 angle. Then I removed some portions of the blue vinyl with a soldering iron. I clecoed the assembly together and used a 7/16” unibit to open up the tooling holes in the ribs for the latch pins. I laid the door in place on the fuse—it will require some slight trimming of the outer door skin to fit the opening on the fuse.
All parts deburred,vinyl removed
Door clecoed together
Initial trial fit-will need some trimming
Copyright © 2001-2021 Matronics. All Rights Reserved.
