Steve & Nancy Riffe
Date:  1-16-2011
Number of Hours:  1.80
Brief Description:  R. Wing-set aileron neutral
I set the right wing aileron to “aileron neutral” using the tool I had previously made. Then I touched up a couple of areas with primer that had gotten scuffed while hanging the ailerons. Connected the long pushrods to the bellcranks. Using the ends of the long pushrods, I did several “aileron rolls”—worked out pretty well—now back to work. Got the flaps out and began reviewing plans.
Both aileron pushrods adjusted to neutral
Large and short pushrods connected to bellcrank
Operating the ailerons
