Brett called me today from Bonaco and suggested I put a fitting at the bulkhead. He is right. After the wing is on, if this tube gets a hole it would be a major problem to fix. So I'll approach this in a couple steps. First I'll put a 45 degree elbow at the bulkhead because you can see in the photo the tube approaches from an angle, not straight on.
