Brief Description: Fuel Lines from Bonaco 5: Order Tubes
I measured and ordered fuel lines from Bonaco. I have two flop tubes and Andair fuel selector. I ordered:
2x 29 inch with 90 degree elbow at one end. 1x 20 incher for selector to firewall 1x 90 degree AN fitting for aft end of Andair pump and I'll make a 3 inch aluminum tube to finish it. 1x 45 degree AN fitting for the front of the Andair pump to send line down thru panel.
I just didn't like the aluminum tube in the fuselage under my legs. The Bonaco lines are teflon coated with steal braid and plastic over the steel so no chaffing.
I forgot to take photos when I received the fuel lines, so the short one is installed. But here is what they look like. I have to change the length of these two. see later entries
