Brief Description: Fuselage Final Items: Air inlet scoops 2
In addition to using Proseal to glue these on, I'm putting 6 rivets in each one. I clamped them in place and drilled the holes. Then I dimpled the holes #40. I plan to use flush #40 pulled rivets.
With light shinning thru you can see the flange overlap.
