Brief Description: Fuselage Final Items: Air inlet scoops 3
Next I made a bunch of little square washers for the back of the air inlet for the rivets to hold. I made a strip and used my accordian drilling guide to drill a bunch of holes. Then I cut the pieces to length.
I tested using solid rivets but the solid rivet expanded on the inside of the plastic and pushed the two sheets of aluminum apart. So I will use the pulled rivets.
